So, for your problem. You've gotta take a knife or a small screwdriver and lever the upper inside part of the fan regulator. It will then slide off very easily. That's it. Good luck and success
Zuletzt geändert von Dr. PuuhBaer am 19. Juni 2007 22:27, insgesamt 1-mal geändert.
Just take a small screwdriver and use it as a lever. You can also use a knife, but you have to be careful, otherwise you can damage the plastic with the sharp side of the knife.
