Winter Blende
- cjoctavian
- Motor: 1,4 TSI
- Kilometerstand: 19600
Winter Blende
Does someone have this mask? Is engine faster in right temperature in winter?
- SKODA OCTAVIA 2008R.(ZDJ NR4.jpg (168.28 KiB) 9740 mal betrachtet
- cjoctavian
- Motor: 1,4 TSI
Re: Winter Blende - fur Facelift
Nobody???
- Lani
- Spritmonitor-ID: 320521
I don't think that anybody does have this mask. Some of the users here have a shield of paper or anything else infront of there cooler, but it should not have a big effect. The Octavia has like most others new cars two coolers. So if you block the bigger front cooler, it will not have a big effect for the small cooler around the motor. The big cooler just get in use if the small cooler inside get over 80°C ( not 100% sure about the temperature ) water temperature.
- Klinke
- Threadfinder
- Spritmonitor-ID: 225397
It seems that german car drivers doesn´t need this.
Really, I don´t have a clue for what I´ve to look for, for helping you. Some users prepaire their radiator with es thin piece of pasteboard.
There is a pretty small effect that is not worth the money - except you live in Alaska or Siberia or drive often in heavy snow falls. But it may help to keep the temperature longer or on a higher level if you often stop the engine for half an hour and then go on like a taxi driver.
- cjoctavian
- Motor: 1,4 TSI
It costs only 12€. I have ordered it - but I don't hope in any big effect... Just some kind of change for winter - and maybe less aerodynamic drag
And I drive a lot in town - with cool engine for short distances
- Klinke
- Threadfinder
Ok, in this case it can be useful for you. Keep us under information, how it works.
- Blue_Sky_20
- Kilometerstand: 75000
- Spritmonitor-ID: 322717
And how about the contamination of the engine compartment? Could this be helpful as well?
Carpe diem
- cjoctavian
- Motor: 1,4 TSI
My friend (who has it on Octavia 2 before Facelift) told me, that its very good to protect enginebay from little stones and salt+mud in winter... But it has almost no effect on warming (maybe a few seconds...)
- Blue_Sky_20
